Car tries to start by itself after pilot bushing install?
Old Apr 24, 2005 | 03:12 AM
raxxus's Avatar
Unhappy Car tries to start by itself after pilot bushing install?
I just got finished reinstalling the transmission after replacing the pilot bushing, and when I went to put the battery back on, the second the negative line hits the battery there is a huge spark and the car attempts to start by itself! There are no keys in the ignition, and it cranks over ( acc. belt spins and everything ) When I parked it, the car ran fine, other then the pilot bushing was out. Anyone have any ideas? Thanks!
Old Apr 24, 2005 | 07:55 AM
bt96ss's Avatar
Re: Car tries to start by itself after pilot bushing install?
redo your starter. loosen the nuts an rotate the wires away from each other. Most likely the small wire causing the problem since the larger has a tab on it. You have the wires touching down there. I did the same thing once it easy to do.
Old Apr 24, 2005 | 08:02 AM
Your problem might be that there is no negative wire that goes to the battery-only the purple wire from the switch and the large positive battery cable.
Old Apr 24, 2005 | 12:09 PM
raxxus's Avatar
Sorry shoebox, I'm going to blame it on newbie ignorance =) Not everyone can know there car like you do! So don't be mean! Thanks tho, I thought it was starter related. I will do that tonite and post what happens!
Old Apr 24, 2005 | 12:43 PM
Pandamonkey's Avatar
Shoebox - being mean?
I've never seen him as anything but helpfull........
Me no understandy.
Old Apr 24, 2005 | 01:25 PM
bt96ss's Avatar
Check the starter first. Loosen the small nut and turn the small wire around away from the large wire. I bet that's it. I'll bet the small wire is contacting the large terminal energizing the starter.
Old Apr 24, 2005 | 01:39 PM
masiroc566's Avatar
Hi...check your starter solenoid. My truck did the same thing. I changed the solenoid and bingo....that is what it was.....
Old Apr 25, 2005 | 12:49 PM
Birdman7389's Avatar
My money is on this option as well. I did the same after my 1st longtube install.
Noenav
Mar 1, 2019 07:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
bossco
Nov 29, 2014 10:18 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
