Car stalling and poor idle.
So I have a 93 z28 and it is having poor idle and stalling sometimes as well as misfiring. Other times it will drive completely normal. Sometimes it will die when driving but will turn back on after about 3 seconds of just rolling and giving it gas. I’ve already changed my fuel pump due to low fuel pressure and the egr and air are deleted. Not tuned out though. The only codes I have are code 26 and code 63. Does anyone have an idea of any test I should do or what could be the issue. My car also started blowing blue smoke but I believe that is to due with the car current having no mufflers on it. Basically being straight piped.
Re: Car stalling and poor idle.
Did you check the circuit on the Bank O2 open circuit (DTC 63)?
Are you running open collectors on the headers (no mufflers)? That can really screw up the O2 sensor readings, and cause the engine to run excessively rich. “Rich” is generally black smoke. Blue smoke is generally oil. Have you checked the plugs for fouling, wet fuel, oil?
Not sure on the stalling…. ICM, Opti…. But should set codes.
One possibility is to download the free Scan9495 software (works on 93 too), get a cable, and scan the ECM. You can run a data log (records sensors and critical ECM parameters) while driving, and I can take a look at it to see what is going on.
https://www.camaroz28.com/forums/com...95-lt1-874306/
Pneumatic_Tire
3rd Gen / L98 Engine Tech
9
Mar 14, 2012 03:26 PM
