Car not giving key back
Old 05-02-2006, 09:08 PM
neil350's Avatar
It will move forward but I cant remove the key, wont turn to unlock. I used Shoeboxs guide of adjusting the park shift cable and it gets the key out but its doing it more and more often. Could the problem be else where?
neil350 is offline
Old 05-02-2006, 10:46 PM
firebird84's Avatar
Re: Car not giving key back
yeah it could be your MLP.
firebird84 is offline
Old 05-03-2006, 11:14 AM
98supersport's Avatar
My wife's Grand AM had what sounds like the same problem. Her shifter had a neutral position safety sensor built in that would allow the key to be removed when the car was in park or neutral. When the sensor died the car decided to keep the key. The car also would not start anymore until we replaced the entire shift assembly. If you're car won't start either this may be it.
98supersport is offline
Old 05-03-2006, 05:13 PM
neil350's Avatar
Car starts fine, just wont give the key back
neil350 is offline
Old 05-03-2006, 05:29 PM
Dave89IROC's Avatar
it sound like it is related to the shift interlock cable
drop the column down and disconnmect the cable from the ignition switch, see if it still does it
Dave89IROC is offline
Old 05-03-2006, 05:59 PM
Critter's Avatar
turn the wheel all the way to the left as far as you can to where there is no slack at all and try it.
Critter is offline
Old 05-03-2006, 07:07 PM
GhostZ28's Avatar
haha your car doesnt want you to stop driving it!
GhostZ28 is offline
Old 05-03-2006, 08:30 PM
94Z28WP's Avatar
Sounds like the rod from the key to the ignition switch is binding... I had mine do this once when I replaced my ignition switch... I had to drop the column and loosen the two screws that hold the switch to it and move the switch a little.
94Z28WP is offline
liamcg97
11-25-2019 05:55 PM
Hurin
12-13-2014 07:38 PM
tds1213
11-27-2014 12:55 PM
USAirman93
11-24-2014 03:37 PM
Quick Reply: Car not giving key back
