Car dead...Wont start
Old Mar 21, 2008 | 08:21 PM
Sweetz28_72's Avatar
I got a new starter because the old one looked in bad shape and the solenoid wouldnt pull in also.....So now I am stuck I havent had the codes pulled and my car is sitting on stands now because of the brake problem I stated in another thread...I am gonna have to get a code reader I guess so I can pull the codes but I will tell you this If I energize the solenoid the car will start and run fine but it will not send power to the solenoid with the keyswitch
Old Mar 21, 2008 | 11:44 PM
euforia51's Avatar
Just a thought... check the ignition switch that's bolted about mid-way down the steering column. Mine burned out (actually melted) a couple of years ago and it was dead like yours.
This is the bracket it's mounted to (steering column has been removed).
And this is the melted connector to the switch. If I remember correctly, there are actually two connectors going to the switch. The other one not shown has some 3-4 heavy gauge wires on it.
Old Mar 22, 2008 | 07:31 AM
Thanks I will check that....I had the same problem you had with it back a couple of years ago when I owned it the first time, burnt the same wires and everything I had to get a new switch and cut that connector off and install new terminals on it and that got it up and going
But right now, I was wondering since its been awhile if there is a breakdown of the starting circuit....hmmmn I wonder if that shoebox link has anything?
Old Mar 22, 2008 | 08:02 AM
Is there anyway to pull the codes on the 95fbodies without a scantool? I had a real nice scantool but the screen got left in the sun and is ruined now so I would have to go borrow one now I guess.....
Old Mar 22, 2008 | 11:21 AM
No, you need a "real" OBD-I scanner (with an adapter plug for the 95's 16-pin connector) to pull the codes. But, if the engine runs fine after you jumper the solenoid, its not an engine problem that would set codes. The PCM doesn't monitor anything other than the PASS-key system, with regards to starting.
Shoebox has everything you need:
http://shbox.com/1/starter_charging_95.jpg
http://shbox.com/1/ignswschematic.jpg
http://shbox.com/1/schematics_wiring.html
Old Mar 22, 2008 | 11:26 AM
The scanner I had was a real nice it covered all OBD-1 cars and had different modules for different makers, I will have to pull it out and see if my snapon guy can get it repaired for cheap....lol I paid almost $300 for it(3 years ago)
Old Mar 26, 2008 | 07:10 PM
Fixed
Well finally I got a few more minutes to work on the Z....Well I used a schematic I got from Shoebox and found that the +yellow wire that comes from the Keyswitch and goes directly to the TDR(theft Deterant Relay) had lost voltage between itself(keyswitch) and the TDR...........For some reason the previous owner had cut into that wire and soldiered it back together only thing is he didn't actually soldier them back together LOL....I repaired the wires with heat-shrink butt terminal and everything is good
....Well except my rear brakes still not working
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
