Can I grind the brake booster to make room for SLP CAI?
Old Oct 12, 2004 | 06:52 AM
ChrisS95TA's Avatar
You know that little metal piece that sticks out between the CAI tubes on the SLP and I imagine it gets in the way with every CAI......can I grind it or something? SInce I installed my vortec intake elbow it shifted just enough to make it grind against the CAI and make a HORRIBLE noise like something is broken in the engine Thanks for any help!!
Old Oct 12, 2004 | 07:54 AM
Kataklysm's Avatar
Re: Can I grind the brake booster to make room for SLP CAI?
The brake booster is against the firewall, your CAI shouldn't be near it. If you're talking about the ABS unit then I wouldn't touch it if I were you. Don't mess with the brake lines unless you don't want to stop
Old Oct 12, 2004 | 08:23 AM
ChrisS95TA's Avatar
Yeah thats it the ABS duh......well, if anyone knows the little **** that stick out I am talking about hopefully I can do something about it
Maybe that is why I had an ABS light, that thing was bumping against it. I cut an inner tube from a bike and put it around that thing and where the CAI is mounted, hopefully that will quiet it but it still is making noise when starting the car and under heavy load from 1st gear at a stop
Old Oct 12, 2004 | 09:19 AM
Kataklysm's Avatar
The **** you are talking about, does it look kinda like a bleeder screw? Don't mess with that or you won't be able to bleed the brakes if you need to.
Old Oct 12, 2004 | 09:25 AM
ChrisS95TA's Avatar
http://shbox.com/1/abs_wiring.jpg
In this pic you cant see the **** (or whatever it is) but it would be to the left in that pic hidden under the CAI. The thing is from the rubbing the **** is already about 1/4 worn down and all shiny LOL
Old Oct 12, 2004 | 11:36 AM
jeremyferguson's Avatar
I took the abs unit off about 3 months ago. Spent about $5 on fittings and $5 on the brake fluid that I flushed the system out with. The brakes feel better and more responsive than ever. Took a lot of the clutter out of the engine compartment too. I've never heard of anyone regretting taking off the abs.....and no, there was nothing wrong with my abs before I took it off, I just didn't want it and I don't drive the car in the winter....
Old Oct 12, 2004 | 12:10 PM
ChrisS95TA's Avatar
I drive in the winter, and use the ABS not alot but I do....my light was on the other day and I smoked up the tired stopping too hard
Old Oct 12, 2004 | 12:34 PM
If you decide to grind something off to make the cai fit and it screws something up, let me know...I have my abs unit in the garage still and its only got 40K on it.
Old Oct 12, 2004 | 01:00 PM
Lower's Avatar
Wouldn't removing the ABS be similar to running drag skinnies on the front if an accident were to ever happen? What I mean to say is that if you were to get into an accident that was not your fault, but a good inspector found that the ABS had been removed -could you be found at fault? It seems to me you could. Additionally, I'm pretty sure that the insurance rate you're paying is for a car with ABS, Air Bags, et cetera. Messing with them I would assume would make your insurance company pretty pissed post accident.
Just a thought, and probably an incorrect one at that.
Old Oct 12, 2004 | 01:04 PM
1991l98g92's Avatar
wouldn't the best CAI for your car be the 96 SS hood and filter assy? Why hack your car when you can install something that fits and looks much better from the outside. If your modifying your car to get the best performance money shouldn't be a factor.
Old Oct 12, 2004 | 01:06 PM
1991l98g92's Avatar
I was thinking Camaro, but a Firebird.....Ram Air......What's the problem?
Old Oct 12, 2004 | 02:06 PM
ChrisS95TA's Avatar
Money, got the SLP CAI a few years ago cheap and I have better things to spend money on than a hood and ram air filter assembly....like my busted up front fender, or my future transmission rebuild since I now have some chatter when off the clutch
Old Oct 12, 2004 | 02:11 PM
ya, your right about the insurance rate, but as far as fault....michigan is no-fault anyways...which means no matter what happened in the accident....each person's insurance company pays for the damage to their own car, not the other person's.....plus I drove my car about 300 miles this summer so far(not my fault I work a lot, and I don't drive it to work).
We don't have any vehicle inspections in michigan either.....
May sound silly, but the reason I took it out was because I couldn't stand the way it looked, and I like the feel of regular brakes over abs brakes.....and if I want to lock-em up I can, if I want to stop fast I can do that too.
Old Oct 12, 2004 | 02:13 PM
IROC-T's Avatar
Couldn't you heat the area that is rubbing on the CAI and push it in (indent)slightly so it doesn't rub. Maybe a BIC lighter or propane torch heat the plastic alittle to soften it and push in (being careful not to melt it or push through). I would not recommend messing with the brake system in any way unless you are going to run off road only.
Old Oct 12, 2004 | 04:11 PM
ChrisS95TA's Avatar
Good suggestion I will maybe try that, I seemed to have minimized it just now by shifting the CAI and wedging rubber tubing on the mount, no more rubbing it seems for now. If it rubs again I will try to heat it and see what happens, thanks again
Kyle@SLP
Jan 7, 2015 02:09 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
97 RedSS
Jun 10, 2003 07:58 PM
Thebeast431
Aug 25, 2002 05:06 PM
Thebeast431
Aug 8, 2002 01:39 PM
