Camaro SS Torque Arm?
Old May 26, 2005 | 01:58 AM
quick96ss's Avatar
Is the torque arm for a 1996 SS stock or not? If not should I upgrade?
Old May 26, 2005 | 06:35 AM
teke184's Avatar
Re: Camaro SS Torque Arm?
not sure i understand...
if you mean "did the 96 SS get a new TA as part of the SS package?"...than NO.
that was not part of the upgrade. a TA will help plant the rear end during launches and cornering. but i don't think it's a mod typically done till alot of other mods are done first.
BUT...
i do recommend replacing the bushing on it with a poly unit. it will stiffen up the stocker quite a bit.
Old May 26, 2005 | 10:51 AM
RE AND CHERYL's Avatar
The SS cars had the same torque arm. Upgrading the arm is not necessary, but installing a poly bushing is a good idea. Many people beleive the stock suspension is junk. No so, I've got a friend with a procharged 01 SS A4. With a little juice it runs 10s with 1.5ish 60fts with nothing more than boxed stock LCAs and full poly bushings.
87Aerocoupe
Jan 10, 2015 07:27 PM
tubby
Oct 13, 2003 09:16 AM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
