Camaro keeps dying !!! Battery drained!
Old May 16, 2012 | 06:23 AM
Javi_1591's Avatar
It's my 2001 z28 . The alternator passed all test n the battery was good . I even bought a new optima battery car died the same day on me n when I got a jump couldn't even hold the charge down the block ha to get it towed . Anyone know where to start
Old May 16, 2012 | 11:13 AM
mrmint69's Avatar
Re: Camaro keeps dying !!! Battery drained!
Battery should have been fully charged when you installed it. It will last for a little while without even having an alternator recharging it. Your connections should be checked and cleaned. Sounds like you have something not hooked up right or the connection is dirty or bad. Have you done anything to the car recently that might explain this? Have you had the battery checked to see if it was bad to start with?
Old May 16, 2012 | 11:50 AM
Javi_1591's Avatar
Well I barely had put the the new battery n drove it in night bout 20 miles n then it died. A while back i had put an alarm n stereo n it had died once but I recharged the battery n lasted about 2 months . Could it be something with the fuse box or maybe the cables that connect the battery to alternator are worn
Gtpguy
Jan 26, 2015 04:50 PM
ddr698
Dec 31, 2014 09:16 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
Sarahrope64
Nov 27, 2014 11:17 AM
