A/C question
Old Aug 11, 2009 | 09:17 PM
Camm95Z28's Avatar
A/C question
Hello. I have a 95 Z and my A/C blows warm air with a touch of cool mixed in. I was told I needed a new LOW pressure switch or possible clean the one I have. Any of these worth while or is this another issue with the system? Thanks
Old Aug 12, 2009 | 02:07 AM
cusz28's Avatar
to vague to really tell. having a bad low pressure switch WILL cut out the compressor causing warm spells, yes, but also having a leak or low charge will cause short cycling and the same symptoms. there is no point in trying to clean an a/c sensor, as the only thing the sensor touches is oil and refrigerant. when they go bad you just replace them. Before you go buy anything, just make PLENTY sure you dont have a leak and that you have a full charge. once you install that sensor, you cant take it back.
Old Aug 12, 2009 | 11:31 AM
Camm95Z28's Avatar
Doesn't appear to be any leaks. Will quick changing out the switch cause anything to leak or evaporate from the low pressure side.
I prefer to do this by myself as this time of year, AC specialists morph into bandits and robbers around here.
Old Aug 12, 2009 | 06:04 PM
cusz28's Avatar
not me, i'm a nice a/c specialist. the pressure switches are screwed onto a nipple with a schreader fitting on them. just unscrew it, but make sure the car is off.
Old Aug 18, 2009 | 07:03 AM
tps07's Avatar
I tried using the quick charge kit from walmart - the one that comes with moisture remover/leak sealer/oil. Worked great. Very easy.
Old Aug 19, 2009 | 09:12 PM
cusz28's Avatar
thats cool (no pun intended).
HectorM52
Jun 23, 2016 08:42 PM
jasonduaine
Mar 7, 2015 09:44 AM
grgguy
17
Feb 23, 2015 07:57 PM
alphaauto
Feb 5, 2015 05:25 PM
pologreen97z
Dec 2, 2014 10:42 AM
