a/c evap sensor
Old Jun 25, 2006 | 08:07 PM
97SprChrgd383's Avatar
a/c evap sensor
The dtc 71 came up on the datamaster, and that is the a/c evap sensor failed. How hard is it to replace this sensor? If anyone knows where I can find a step by step, that would be very helpful.
Old Jun 25, 2006 | 08:21 PM
OffspringZ28's Avatar
Re: a/c evap sensor
what are the symptoms of this?
Old Jun 26, 2006 | 06:42 AM
Re: a/c evap sensor
No cold air blowing out. We recharged the a/c, and checked everything else. I thought at first it had something to do with the wiring harness, because there was no service light wasn't on, and I hooked the datamaster up to the car, turned on the a/c and this dtc 71 came on. Says it's the a/c evap sensor.
Old Jun 28, 2006 | 01:35 PM
Re: a/c evap sensor
compressor is kicking on right? and did you replace the evap sensor?
Old Jun 28, 2006 | 01:44 PM
Re: a/c evap sensor
I didn't replace the evap sensor. That's the error I am getting and I'm wanting to replace. Is it hard?
Old Jun 28, 2006 | 02:34 PM
Sholt_c33's Avatar
Re: a/c evap sensor
If you are refering to the a/c refrigerant pressure sensor it is located in the a/c line from the evap to the dryer...just unplug the connector and unthread it...the part number is 22664328 $55.45 Canadian...hope this helps...
Old Jun 28, 2006 | 06:43 PM
Re: a/c evap sensor
The evaporator sensor is stuck in the fins of the evaporator under the dash. Heck, it might just be unplugged.
Old Jun 28, 2006 | 06:46 PM
Dave89IROC's Avatar
Re: a/c evap sensor
I might have a pic of the location, I'll look
Old Jun 28, 2006 | 08:50 PM
Re: a/c evap sensor
That would help alot. That could be it. Is the plug wire a part of the wiring harness?
Old Jun 28, 2006 | 09:30 PM
Re: a/c evap sensor
It plugs into the harness that comes from the computer. (remember, you can click on sections of that pic to zoom in)
KYWes
Jun 14, 2022 06:52 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
