A/C compressor won't kick on
Old May 9, 2006 | 07:11 PM
NYC32798's Avatar
Question A/C compressor won't kick on
I went to turn my a/c on and all I got was warm air. I checked under the hood and noticed the compressor was off. I figured maybe it was low so I went to the store and picked up some r134 and put some in and nothing happened. All the fuses are fine and so is the connector on the compressor. I also installed the hypertech programmer so could that possibly cause a problem? I know most of you will tell me to just rip it out but it's currently an everyday driver and my girl is driving it. Plus it's way to hot in Florida to not have it. Any ideas?
Old May 9, 2006 | 07:39 PM
n2ceptor's Avatar
Re: A/C compressor won't kick on
Clutch Cycling Switch...... Possible....
Old May 9, 2006 | 07:47 PM
playa7970's Avatar
same thing happend to me still trying to figure out what it is what part of FL do u live
Old May 9, 2006 | 11:52 PM
NYC32798's Avatar
I'm currently living in Orlando for school. It's starting to get pretty hot out which is why I must fix it ASAP. Rolling the windows down won't cut it. It's too damn hot. I went to an a/c convention for school and won a free a/c compressor so if I need one I can get one cause I got a feeling if I bring it to anyone around here to take a look at it they will try to rape me and say I need a new compressor but I don't think it's the compressor itself. It's probably something stupid like every other little bs thing that goes wrong with this car.
Old May 10, 2006 | 03:30 AM
camaroz2866's Avatar
hey u can give me a call if u would like and i will try and walk you through it but, get somesort of power tester, weather its a multimeter, or a logic probe or something to check if u have power to the compresor with the controls on the dash "on", once u check that, if u do have power to the compressor, then the compresor is bad(since its not coming on) if you do not then we have to check a couple more things, numbers 972 746 8925 names jake
Old May 10, 2006 | 12:31 PM
lt1srule's Avatar
all your have to do is unhook your battery for a couple of hours and reset computer.When freon is low it senses it and shuts power to compresser so u dont fry it.i had that happen to me that fixed it\
Old May 10, 2006 | 02:19 PM
fastchevy's Avatar
Hopefully you added refrigerant also
I'm replacing my compressor, drier, expansion valve, and orifice tube in mine. It should be nice, cold, and worry free
Old May 11, 2006 | 08:29 PM
NYC32798's Avatar
I'm just curious. I took the programming out of the ecm and i'm not sure if that resets the ecu or not but I tried the a/c anyway after I took it out and it didn't kick the compressor on. I unhooked the battery anyway but I just wanted to know if pulling the program out reset the ecu. Camaroz2866, Thanks for the offer on the help. I will contact you if this doesn't work.
Old May 13, 2006 | 01:07 PM
NYC32798's Avatar
I did what lt1srule said to do and it worked. It didn't blow cold air at first so I put some r-134a in and now it works so I guess there is a leak somewhere I got to find. Thanks for the help.
Old May 17, 2006 | 11:49 PM
glenn's Avatar
I'm having the same problem with my son's 94 Z28. I tried shorting the high pressure switch and I heard the fans come on, but the compressor was still not turning. I had a gauge hooked up to the suction side and it was at 130 psi, is this a good pressure when the compressor is not turning.
I'll try disconnecting the battery to see if I can get the compressor to start turning, then I'll see if it will take some freon.
Old Jul 3, 2006 | 05:19 PM
dfuhry's Avatar
i have the same problem with my 95 trans am and just replace the compressor and it still does not turn on, if anyone could give me any tips that would be great
Old Jul 4, 2006 | 12:29 AM
glenn's Avatar
This thread helped me tremendously. I was about to get a new compressor, then I decided to disconnect the battery to reset the computer. It worked like a charm. I put in a couple of cans of 134a and it's worked great ever since.
Old Jul 4, 2006 | 08:44 AM
j-dub's Avatar
you probably set a dtc code. you will need a tech 2 scanner to reset the code.
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
michael42869
Parts Wanted
Aug 3, 2015 10:22 AM
Boss002
Jul 24, 2015 10:47 AM
