A/C Compressor Questions..
Old Jun 15, 2005 | 09:46 AM
Ucantcme57's Avatar
Last summer I refilled my A/C system cause it wasnt working.. Took two cans.. The first can got the compressor going.. The second can got it cold.. After I filled it I could hear a psshh sound very lightly.. I poured soapy water on it and could never see any bubbles.. at the end of the year the A/C quit one day while I was driving.. I pulled over and the front of the compressor where the pulley is was ice covered.. the air no longer worked? Did I blow the front seals? Could the schrader valve be bad too? How do I check.. I was told by my friend to just buy a can and see if it comes right out the front of the compressor but I don't wanna waste 8.99 per can at autozone.. And Ideas...?
Old Jun 16, 2005 | 11:50 AM
Ucantcme57's Avatar
Re: A/C Compressor Questions..
Am I black listed or something??? No replys.. What so ever???? It's been a whole day.. I answer others when they need help.. What's the deal...
Old Jun 16, 2005 | 12:14 PM
White Knight 95's Avatar
If there was ice on the compressor, then that is where you have a leak. Keep in mind that a leak near the compressor may freeze on the compressor as well. Personally, I would pull it apart to see if there are any obvious leaks.
Old Jun 16, 2005 | 06:10 PM
tom2's Avatar
Best bet to pull a vacuum and see if it will hold it. I'd say the front seal let go, not a cheap repair any way you look at it. There may be a high pressure cut out on the back top of the compressor, these tend to leak after converting to R134 but don't think it would frost the front of the compressor. Be glad it's not the original R12, really big money there.
2QUIK6
Sep 17, 2016 02:31 PM
magman
Apr 15, 2016 03:08 AM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
