A/C Compressor disengages when I hit 52 MPH and beyond?
Old Jun 28, 2011 | 11:25 AM
68camaroboltz's Avatar
Hi there,
I have a unique situation. It is hot in cali and I could use air on my commute. My 2000 Camaro Air Conditioning works until I am on the freeway and the mph exceeds 52 mph. You can feel the compressor turn off and on trying but blows hot air. When I get off and drive from the off ramp and lower mph it come on and blows cold. The freon is fine. I replaced the Hi/Low pressure sensor/switch.
Any Idea's?
Thank you so much!
Old Jul 4, 2011 | 11:41 PM
L.dookie's Avatar
Re: A/C Compressor disengages when I hit 52 MPH and beyond?
are your fans working?
Old Aug 9, 2011 | 02:01 PM
Hi there,
Sorry it took so long but I could not log in for some reason but still have my problem!!!! If you mean the car fans where you turn on the console....yes. What happens is when I get to that speed or rpm it goes from blowing cold to hot and you feel the compressor going off. I now this is too weird???
Thank you and I can log on now luckily!
Old Aug 11, 2011 | 08:16 PM
Nickw059's Avatar
How can you tell its engaging and disengaging when you go over 52? Thats merely impossible to feel. a/c has nothing too do with how fast you go either, unless your just sitting around idiling than you would feel a diffrence. possible bad connection? It kinda sounds like your a/c system is freezing up. in that case it would freeze up, air couldn't go throught the condenser and cool off, thus warm air! that would be your Thermostatic Switch.
HectorM52
Jun 23, 2016 08:42 PM
timmy39120
May 8, 2015 11:41 AM
BigWil
Mar 29, 2015 12:24 PM
alphaauto
Feb 5, 2015 05:25 PM
