bullet mufflers
Re: bullet mufflers
Originally Posted by Sly_Z_28
will a bullet muffler fit on the stock i-pipe on a 94 Z?
Re: bullet mufflers
I hope you are running more than just the bullet...it's going to be LOUD other wise....
Re: bullet mufflers
you should check out my website, bottom of page 2 i think
i have a bullet muffler welded on behind the off-road pipe, a 3" Ipipe and then another bullet with a turndown tucked up under the trunk.
it sounds AWESOME and was cheap. i also painted the rear bullet and turndown with black exhaust paint so that it blends in with the underside of the car. not visible from the back.
Re: bullet mufflers
Originally Posted by Shon Herron
Get the 3" bullet muflfer and have it welded in.
Loud... pshh. You just gotta decide how loud it should be to OTHER people... cuz if you dump way back like mine... it is quite bearable... even with only one bullet, and a straight pipe instead of a cat.
I will get pics.. if you can IM me or anything.. that would be easiest... if not i'll just post.
Re: bullet mufflers
Re: bullet mufflers
i'm going to run a catco cat or stock cat with the bullet and then cut out the stock muffler and put pipe in there to retain the dual exhaust look, it will look stock! he he. The over the axle part will be like the SLP Loudmouth or Borla were there is a y-pipe. I have heard that this setup sounds like the loudmouth WITHOUT the raspy and poping sound!
Re: bullet mufflers
i have the slp loudmouth with the bullet muffler welded in place of the slp resonator, and I do not have a "poppy sound". I think it sounds really good, especially at highway speeds
Cory
Cory
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
