When I bought my car I noticed the window would slide back and forth I took off the door panel off and the wheel that goes up and down in the verticle track is broke off and gone looks as off I have to pull the window out of the door I tried to get It out but don't seem to fit any suggestions on how to get it out
Probably help if you provided info on the year of the car.
Why not add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That gives people the info they need to help you.
My bad it's a 94 z28
In order to get the window out you have to take the whole crank assembly out and then the clips off of window. This may be common because before I fixed all my windows I noticed my vertical roller had been welded in place. I have a extra window I would be willing to sell fairly cheap. Not sure if that bracket comes off or not. I will check later. If so I could just sell the bracket.
Sent from my Z796C using Tapatalk
Well Its all pop riveted together so was hoping it came out as one piece so I didn't have to mess with trin g to put it back together I was gonna drill and tap the old wheel and bolt it back on but I had it in my cup holder and my wife decided to clean my car out
