Brights won't work.
Old Feb 20, 2014 | 07:56 AM
Armyjoe88's Avatar
Brights won't work.
So I replaced my turn signal switch in my 99 z28 and ever since my brights havent worked. It doesnt even click when I pull the switch. But the turn signals and everything else on the switch works.
Old Feb 20, 2014 | 05:47 PM
parkers Z28's Avatar
Re: Brights won't work.
Was it a oem switch ??? have you checked the fuse / relay ?
Old Feb 20, 2014 | 06:53 PM
Armyjoe88's Avatar
It isn't a fuse or relay. Because when you pull the bright switch usually it clicks. Now it doesn't do anything. The switch I installed was an AC Delco switch from an auto parts store. Everything works but the brights.
Old Feb 20, 2014 | 07:46 PM
figured that just.
Something must have went wrong in the installation or you have brand new switch that doesn't work
Just curious have you tried to use it in both directions ??
Old Feb 22, 2014 | 03:57 PM
The actual dimmer switch is on the lower part of the column. You might want to check to see if the rod from the stalk is actually moving it far enough to operate it.
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
rideordie
Sep 7, 2015 08:22 AM
