brake master cylinder
Old Feb 19, 2015 | 07:22 PM
ModdedNerd's Avatar
any tip or tricks i have to do this tomorrow......
Old Feb 20, 2015 | 07:03 AM
Re: brake master cylinder
Not sure if you are familiar with the process:
-Bench bleed new master before installing. The best thing to do is consult the factory manual if you are not familiar with this. I could e-mail you a .pdf of the correct pages if you need it.
-Use only DOT-3 fluid, from a sealed container.
-If the brake fluid has never been completely flushed and replaced, now is the time to do it. Takes about 1.5 quarts of brake fluid.
-Flushing and bleeding the braking system is complicated by the ABS system. There is a detailed procedure in the factory manual (Section 5E1, page 164. Again, can e-mail a .pdf, or go to this site and download the 1996 factory manual for free:
LINK: 4TH GEN SERVICE MANUALS
You may have to join the site (Firebird Nation) to download.
Old Feb 20, 2015 | 08:41 AM
ModdedNerd's Avatar
damn its that complicated? lol
i thought it was bleed master, take old off, put new on, bleed brakes according to the haynes manual.
sure ill take the manual its the same as my name on here just @gmail.com
Old Feb 20, 2015 | 09:26 AM
I am only going to send the pages I mentioned. If you want the entire manual, you need to download it.
Old Feb 20, 2015 | 10:39 AM
ModdedNerd's Avatar
thanks
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
timmy39120
May 2, 2015 05:12 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
