Brake lines: 45 or 37 degree flare?
Old Feb 14, 2006 | 06:17 PM
RamAir95TA's Avatar
Hey guys:
I just finished bending up and flaring brake lines for my Ford 9", and they don't seem to be sealing up well at all. They tend to slowly drip and leak fluid. I used a 45-degree flaring tool that I have had for awhile. It has only been brought to my attention that there are also 37-degree flares as well. My question is:
What degree flares come from the factory? Are 37-degree flares the standard for automotive applications? Or should 45-degree seal without a problem? Thanks for your help.
Old Feb 16, 2006 | 01:07 PM
RamAir95TA's Avatar
Re: Brake lines: 45 or 37 degree flare?
Anyone?
Old Feb 16, 2006 | 01:29 PM
rngilliland's Avatar
I think you need to use a metric bubble flare.
Old Feb 17, 2006 | 01:20 PM
RamAir95TA's Avatar
What kind of flaring tool does that?
Old Feb 17, 2006 | 10:07 PM
http://www.thetoolwarehouse.net/shop/SK-90428.html
Old Feb 4, 2008 | 03:06 PM
white97T/A's Avatar
Just saw this old post... but I wanted to add a link incase anyone seaching came across this.
http://www.pharmacy.arizona.edu/staf...ubleFlare.html
Old Feb 4, 2008 | 10:29 PM
Stephen 87 IROC's Avatar
AN or JIC fittings depending on what name you want to call them use 37* flares. Old style brake lines use a 45* double flare. Cars made after around the mid 80's use metric bubble flare fittings.
You can keep your 45* flared brake lines on your 9" and buy adapter fittings to connect them to your car's metric bubble flare hoses. Many parts stores carry the metric adapter fittings.
Old Feb 4, 2008 | 10:50 PM
ACE1252's Avatar
Bubble flare....I was wondering what type flare is stock on our cars.
I done the LS1 brake upgrade and worked the hard lines to the stock location on a '98 and up. I was wondering what I'd need if I had to cut and flare the lines.
Now if I can just find a good alignment shop!
Boss002
Jul 24, 2015 10:47 AM
13qtr
Jul 19, 2015 05:30 PM
whitehooptie
Jul 12, 2015 06:10 PM
