Blueprinted engine
Old Jun 15, 2006 | 08:15 PM
camarorock's Avatar
Blueprinted engine
When someone says there engine is blue printed, does this mean its high performance or what?
Old Jun 15, 2006 | 08:21 PM
87DJP2001's Avatar
Re: Blueprinted engine
It just means the critical parts are within tolerance.
Old Jun 15, 2006 | 09:04 PM
Dave89IROC's Avatar
means that every measurement/spec has been checked and corrected to be within the "blueprint" specs for thst engine
and so you know, OEM factory built enginee up until recently were almost never in spec
I know a guy that did spot checks on Ford 302 back in the early 90's that were WAY out of spec(crank centerline to bellhousing alingment wasn't even close), yet thase engines are still out there running today
blueprinting allows for the best performing, longest lasting engine possible, barring any other factors
Old Jun 15, 2006 | 09:15 PM
camarorock's Avatar
Ok thanks
Old Jun 15, 2006 | 09:49 PM
GhostZ28's Avatar
yeah blueprinting is a very good thing, but expensive because it involves lots of time in measuring and fixing things that are slightly off. A blueprinted engine is the only way to go when reaching in the high rpms
Old Jun 15, 2006 | 10:00 PM
94CamaroZ28's Avatar
And while it may well make a bit more power than otherwise, the main purpose is getting good balance (smoother) and longer life no matter how you run the thing. Eliminating tolerance buildups can also allow for significantly longer life due to eliminating parts not lining up perfectly and allow for higher revs where otherwise torsional vibrations might make nasty things happen....
Old Jun 16, 2006 | 07:52 AM
camarorock's Avatar
thanks all
Old Jun 16, 2006 | 08:53 AM
97FormulaWS-6's Avatar
The other thing that wasn't mentioned is that all the measurements are recorded for that engine, from top to bottom; the torque on each rod bolt to the crankshaft clearances to the endplay. It's done on most race engines or test engines to determine wear patterns after races or after XXX miles to determine how much deterioration has occoured inside the motor.
It is very time consuming to adjust and measure every little thing, but it basically assures the motor is for lack of a better word, perfect.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
