turn signal doesn't always work
i have a '97 camaro rs. the running lights work great; both sides stay lit up at all times. the right passenger side turn signal works great. both taillight signals work great. the problem is the front driver's side turn signal. id say about 75% of the time it works fine, but the other 25% of the time when i turn on the signal the light will just go out (no blinking, no running light). im thinking its a problem with the fuse but i really have no clue. any help would be appreciated
Re: turn signal doesn't always work
Originally Posted by shoebox
Probably a poor connection at a socket.
The corrosion is caused by moisture, so anything you can do to keep the socket clean and dry. After I replaced mine, I covered it with dialectic grease. Seems to be holding up fairly well.
stangspank
Nov 13, 2015 01:02 PM
