blinker question
Old Dec 6, 2006 | 07:39 PM
'96WS-6's Avatar
blinker question
Left blinker works, right blinker comes on but does not blink...all of the bulbs work on the right side..at least when I checked earlier they did, and if there was a blinker out wouldnt it just blink extremely fast? Neways if anyone has had this problem and knows the solution please drop a line ASAP. I think it may be a fuse...but I dont have the fuse box schematic so I dont know which size fuse or where the fuse is located in my box. Thanks!@
Vince
Old Dec 6, 2006 | 08:05 PM
shock6906's Avatar
Try changing the fluid...
Oh I just had to. I'd check into the relay under the dash maybe. Sometimes one of my blinkers wants to just stick and not blink. It will not work for a minute or two and then will all of a sudden start working again.
Old Dec 6, 2006 | 08:48 PM
AlfredB18's Avatar
I agree, check the relay. It should be labeled on the underdash lid.
Fuses do nothing but act as circuit breakers. They "regulate" current flowing through circuits, they do not do anything else.
Old Dec 7, 2006 | 07:29 AM
87DJP2001's Avatar
Replace the flasher unit under the dash, a $2.00 item at any Auto Parts store.
Old Dec 7, 2006 | 07:52 AM
ColeSmith's Avatar
same prob except mt left running lights in the front are out along with the blinker, they are brand new(corner lights).
Old Dec 8, 2006 | 05:34 PM
B00SS's Avatar
Most likely the bulb itself. Remove and replace.
Old Dec 9, 2006 | 03:18 PM
Don350k's Avatar
also make shure to check the connections in the bulbs for dirt or corrosion also in the socket for the bulb also
Don
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
