blinker problem
Old Jun 24, 2006 | 10:41 PM
Misfits's Avatar
blinker problem
i jus recently replaced my front passenger blink bulb, and it stilldoesnt work???
if i put on my hazards on, then all 4 do flash,but if i put my right side signal on, the rear one jus stays on and they dont blink..
i jus replaced the front bulb today, i might replace the rear one tommorow..does anyone knows whats going on here?
Old Jun 25, 2006 | 08:13 AM
lastZ's Avatar
Re: blinker problem
i had the same problem......found out that the recepticle was wet inside......i took a hair dryer to the inside of the recepticle, dried it out good, and i havent had a problem since.......not sure why their was water in there butit seemed to do the trick.....hope this helps ya
Old Jun 25, 2006 | 04:52 PM
OBE1 95Z28's Avatar
Re: blinker problem
If your hazards work properly, then it's not the bulbs or a wet socket. May be the turn signal lever or the turn signal relay.
Old Jun 25, 2006 | 10:58 PM
Misfits's Avatar
Re: blinker problem
ok i jus re checked how the lights respond..
if i have the hazards on then 3 of them flash, the front passenger one doesnt.. but the DRL's r on and working fine, i checked fuses and even replaced the front bulb..
could condesation be doing this, cuz i'm gonna look at it again after work tommorow and take a hair dryer and give the connector a nice drying...
Old Jul 4, 2006 | 06:53 AM
MTBeni's Avatar
Re: blinker problem
I have something similiar going on right now. The pass DRL was burned out, so I replaced it. I had 1 left, so I decided to swap out the drivers side too. Now the driver DRL doesnt work and the left blinker wont work. It just stays on.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
