bcm still chimes wen im out of car (no signal )
Old Jul 24, 2014 | 04:06 PM
lt1z2897's Avatar
Ok I made a post few weeks ago. I said my Bcm chimes when I touch it. Well I see that its not my bcm wires. I hold them very tight. An touch the bcm with a screw driver it still chimes 2-3times... my car has no signal. It cranks fine.. #fuel pump doesnt come on.. coil doesnt spark. Icm is good. I primed my fuel pump an it works.. brandnew Pcm. Still nothing. . I was told if my bcm chimes with no key or small touches. Then its #baddddddd???? #shoebox #helpme man
Old Jul 24, 2014 | 04:37 PM
Re: bcm still chimes wen im out of car (no signal )
Generally a good idea to continue the old thread, rather than start a new thread about the same, ongoing problem.
https://www.camaroz28.com/forums/gen...signal-880113/
The earlier thread confirms your car is a 1997.
By "no signal"you explained in the earlier thread that you meant "no fuel pump signal." Appears this is still a problem, and the engine will not start????
In the earlier thread you indicated that when the engine did run, it continued to run when the ignition was switched to "off".
Old Jul 24, 2014 | 08:32 PM
lt1z2897's Avatar
Yes I made a new post cause no1 respond. Sorry about that. But it had stopped staying on for a few months. But my main problem is that my bcm chimes when I touch it. Really bad shortage seems like.. an its not my wires because I will hold them tight an touch the box. It still chimes. Thanks for responding
Injuneer
Dec 15, 2014 09:36 AM
pete53
Dec 9, 2014 07:31 AM
USAirman93
Nov 24, 2014 03:37 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
kandied91z
Aug 6, 2002 01:18 AM
