BCM install
BCM install
I have done a good bit of research on here and come to the conclusion that my BCM is damaged due to a lady hitting me.
My question: Is it a plug and play type of swap or does the unit have to be flashed in some way by the dealer. The threads were not completely clear on that.
Should just be plug and play. I know that the VATS system will program itself the first time power is hooked up and when you put the key in the ignition it will read the chip you have in your key and use that value from that point on.
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
