BCM install
Old Apr 20, 2007 | 11:38 AM
doodad's Avatar
BCM install
I have done a good bit of research on here and come to the conclusion that my BCM is damaged due to a lady hitting me.
My question: Is it a plug and play type of swap or does the unit have to be flashed in some way by the dealer. The threads were not completely clear on that.
Old Apr 22, 2007 | 03:29 PM
TwEaKeDSS's Avatar
Should just be plug and play. I know that the VATS system will program itself the first time power is hooked up and when you put the key in the ignition it will read the chip you have in your key and use that value from that point on.
Old Apr 23, 2007 | 04:20 AM
bmotwani's Avatar
Plug n play. The BCM comes with a corresponding key and the software simply recognizes the resistor value in the key.
Old Apr 23, 2007 | 07:40 AM
doodad's Avatar
So you get a new key with the BCM? That is this first time I have heard that.
Old Apr 23, 2007 | 08:05 AM
Me, too. I don't think so.
I believe it is like TwEaKeDSS said.
Old Apr 24, 2007 | 04:21 AM
bmotwani's Avatar
i had replaced my BCM some time back and the guy had to find the corresponding key to that particular BCM. I couldn't use my old key with the new BCM.
Old Apr 24, 2007 | 07:29 AM
doodad's Avatar
Was that a used one? That would make sense to me.
Old Apr 26, 2007 | 07:43 AM
bmotwani's Avatar
yes the key and the BCM were both used. Sourced from the scrapyard :-)
Old Apr 26, 2007 | 01:16 PM
Used makes the difference. The BCM will only program itself to the key one time.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
