Battery question
Old Feb 5, 2008 | 01:50 PM
reamo04's Avatar
Battery question
okay...so, moving my battery to the trunk
and was looking at using the BMR relocation bracket
http://thunderracing.com/catalog/?ac...vid=4&pcid=105
bow, using that, I still need a battery box, correct?
Old Feb 5, 2008 | 02:39 PM
NHRA requires a sealed and vented battery box, if the battery is located inside the vehicle. You also need a master disconnect, accessible from outside the car.
Old Feb 6, 2008 | 09:55 PM
reamo04's Avatar
so, basically, this is all I need?
http://store.summitracing.com/partde...5&autoview=sku
And a master disconnect
Old Feb 6, 2008 | 10:01 PM
mdacton's Avatar
That looks like it all.....I got the moroso stuff years ago...it was over twice what that cost and it looks like the same box too.
I ended up using a ford solenoid up front for the starter and looped the GM one to the hot side. Sometimes it would click, thought it was a ground but it wasen't.
Get the BIg disconnect switch too......the cheap one is a pc. of junk, you need alot of surge amps. You will also need a wire for the alt. to run it to the back, when you shut the switch off it has to cut the car off.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
nosliw
Feb 7, 2015 01:30 PM
capebuf
Jan 13, 2015 07:22 PM
97z28k&N
Jan 9, 2015 04:58 AM
nophix
Nov 30, 2014 10:26 PM
