basic oil change
Old Dec 28, 2005 | 03:05 PM
1of365's Avatar
basic oil change
Stupid questions but want to make sure. I just did my first oil change on mynew bought 99 SS. I'm using Mobil 1 and WIX filter. The manual says fill with 5.5 qts of oil but i noticed on this web site some say 5qts even. Hope i didn't add too much?
also changed air filter with Wix paper cartridge. The Local auto shop said it is better than K & N if I don't know how to oil and maintain properly...makes sense?
This is a stock 99 SS.
Old Dec 28, 2005 | 03:15 PM
1of365's Avatar
Re: basic oil change
never mind, I found more info when I searched under oil! manual says 5.5 and some change with 6! I had no idea it could take that much of a variance without causing leaks!
This web site is great!
RMC_SS_LDO's Avatar
As for the oil, put 5 qts and drive it till it's warm. Check the level and add if you need..... better to be just a tad low then top off vice over filling.
Allen
Old Dec 28, 2005 | 03:16 PM
1of365's Avatar
thanks! already added 5.5 but will check once it is run a little. this LS1 is so much easier than my other cars! Plug and filter are easy access.
Old Dec 28, 2005 | 03:24 PM
2000GTP's Avatar
Oil and air filter changes are very easy on LS1s, its just everything else that is difficult.
Old Dec 28, 2005 | 03:40 PM
2001NBMZ28's Avatar
I always put 6 in, even with the stock size filter.
Old Dec 28, 2005 | 03:43 PM
PaganEgyptian's Avatar
Most run 6 qts if it sees a track in order to maintain oil pressure in hard turns....
Old Dec 29, 2005 | 01:34 AM
MyShibbyZ28's Avatar
Does anyone ever use the dipstick to check the level, instead of what someone else says? Go by the manual first, dipstick second.
No offense to anyone, but I do see a lot of questions asking simple answers.
Anywho, I put 5-6qts in mine.
grabbem88
Mar 18, 2015 01:25 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
