Asr?
Old Jan 19, 2010 | 07:46 PM
oneclean97z's Avatar
Asr?
I have a switch next to the fog light switch called ASR. If it's on it will make the gas pettle release if the tires spin out when wet or flooring it etc etc. Well it doesn't show up on the dash anymore. Any idea what i can look for or is there a way i can just disconnect it altogether? I know it's more dangerous to have it constantly off but i don't care right now. Thanks for any input guys
Old Jan 19, 2010 | 09:04 PM
94FormulaLT1's Avatar
The ASR stands for Automatic Slip Reduction (if I remember correctly) but is just a fancy way of saying traction control. I believe everytime you turn the car off, it resets it to its normal state which should be enabled. You should be able to check that pretty easy by just going out and trying to spin the tires. You may want to check your fuse box as I believe there is a seperate fuse just for that system.
Old Jan 21, 2010 | 02:57 PM
Well i tested it out and it seems to be working. It is always on when you first turn on the car so hitting the switch once will make it off, and it is working just no light on dash anymore that tells you when it's off. I'll check fuses and go from there
Old Jan 21, 2010 | 03:53 PM
Check the bulb.
Old Jan 21, 2010 | 05:15 PM
Yeah, sounds more like a bulb issue. If it wasn't working I would of gone for a fuse, but since it just isn't lighting up, go with the light.
Old Jan 22, 2010 | 03:30 PM
Alright i'm gonna take off the cover and look back there. Thanks i'll keep this updated
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
dluna333
15
Mar 13, 2015 12:30 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
