Anyone else have this problem?
Old Aug 9, 2004 | 06:30 PM
UofMKen's Avatar
I drive a 2000 Z28 and after about 40,000 miles there is now a considerable gap (about an inch or so) between the fender and the door and the fender is pulled out some. Is this a common problem and is it easily fixed? Or will I have to replace the entire fender...
Old Aug 9, 2004 | 06:41 PM
FastrDamnit!'s Avatar
Re: Anyone else have this problem?
I'm assuming you've jacked up your car from the corner of the body right behind the front wheel well at one point?
This happened to me a while back after jacking the car, all we did to fix it was place the end of a 2x4 up against the underbody fender panel lip near the jacking point under the car and whack the other end of the 2x4 with a mallet/sledgehammer. This will pull the fender back into the body and flush with the door.
Old Aug 9, 2004 | 11:48 PM
UofMKen's Avatar
I didn't jack my car up at that point, but I will definitely try your suggestion, thanks.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
