anyone with alot of time and even more knowledge..
Old Apr 13, 2007 | 03:15 PM
  #16
00ls100's Avatar
http://www.wam.umd.edu/~clehman/cs3/cs3.html
Old Apr 14, 2007 | 01:47 PM
  #17
transAMdriv3r's Avatar
Originally Posted by z28luva
new question. what is low-end torque and top end hp. what does that actualyl mean?
low end torque means that your peak amount of torque is low in the rpm range, and top end hp, means your hp is at its peak at higher rpms.
Old Apr 18, 2007 | 08:10 PM
  #18
z28luva's Avatar
are those both good things?
Old Apr 20, 2007 | 09:17 AM
  #19
angel71rs's Avatar
Good depending on the application. If you have a heavy truck, you'd want the engine components selected with low end torque as your highest priority. Lightweight Camaro that is going to see mostly strip duty, you go for high rpm HP.
A car that sees mostly street duty/cruising with an occasional trip to the strip... you compromise a bit. Which way and how much depends on personal preference. I run a cam with 224 degrees duration in my 71 mostly because I'm more biased towards torque, so I'm willing to kiss off high rpm HP above 6,000. Someone else that is more of a strip hound would put in a cam with 230-240* for HP > 6,000 rpm.
Good thing about the 396 is that it can make good low end torque AND high rpm HP, mostly because of the excellent heads, especially if it has the oval port heads.
Old Apr 21, 2007 | 07:33 PM
  #20
z28luva's Avatar
thanks alot everyone
Old Apr 21, 2007 | 10:19 PM
  #21
z28luva's Avatar
also another dumb question. what do you mean by 224 degrees duration?
Old Apr 21, 2007 | 10:50 PM
  #22
angel71rs's Avatar
http://www.chevyhiperformance.com/te...iables_basics/
Old May 21, 2007 | 08:55 PM
  #23
lovescamaros25's Avatar
duration is the length of time in crankshaft degrees that the intake or exhaust valve is open.I think you need to find a really nice Automotive Technology text book and read up on the basics.
transam_388
Mar 15, 2015 11:53 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
ModdedNerd
Dec 10, 2014 08:42 PM
omarECD
Aug 19, 2002 07:28 AM
guionM
Jul 21, 2002 04:38 PM
