Alarm Issues
Old Jun 9, 2005 | 08:23 PM
Cincymaro88's Avatar
Alarm Issues
The factory alarm in my 01 SS keeps going off for no reason at all. If i arm it, it takes anywhere from 1 minute, to hours before it will go off. Any ideas on how to fix this issue? Bad sensor maybe?
Justin
Old Jun 9, 2005 | 08:36 PM
ulakovic22's Avatar
Re: Alarm Issues
Play with or unplugged the module on the rear passenger side fender well under your spare tire cover. Mine kept going off so I just unplugged it to see if it would work and it did so I haven't ever plugged it back in to mess with the sensitivity screw.
Old Jun 9, 2005 | 08:37 PM
2001NBMZ28's Avatar
Re: Alarm Issues
Usually if the shock sensor goes bad the alarm goes off almost immediately after it's armed. Try turning down the sensitivity, if that doesn't work unplug it and see if it stops - if it does that's probably the problem.
Old Jun 9, 2005 | 09:05 PM
Re: Alarm Issues
Sounds great guys. How do i adjust the sensitivity of the alarm?
Old Jun 9, 2005 | 09:09 PM
ulakovic22's Avatar
Re: Alarm Issues
There should be something like a set screw on the shock sensor in the back that you can use. I've never done it, but I think that on Brent's site there are instructions.
Old Jun 9, 2005 | 09:33 PM
2001NBMZ28's Avatar
Re: Alarm Issues
The shock sensor is in the spare tire compartment - turn it counterclockwise to decrease sensitivity.
Old Jun 9, 2005 | 10:12 PM
Re: Alarm Issues
Ok turned the sensor all the way down (im guessing its that white turn dial on the side of the sensor). We'll see if it goes off again. Thanks guys.
Justin
Old Jun 10, 2005 | 01:17 AM
Re: Alarm Issues
Well looks like that didnt work out. Alarm goes off still. How do I disarm the shock sensor completely?
Old Jun 10, 2005 | 07:37 AM
BacardiTA's Avatar
Re: Alarm Issues
They were saying to unplug it to eliminate it completely.
Heathen1
Jan 2, 2016 04:27 PM
OutlawPerforman
Jun 15, 2015 12:49 AM
pimpinphil
May 30, 2015 04:20 PM
gelbza
May 29, 2015 05:50 PM
Rich_z28
Sep 13, 2002 03:35 PM
