Air vents not working
Old Mar 24, 2011 | 10:07 AM
Greg88's Avatar
I tried searching, but found nothing, my air vents arent working on my car, where should I start looking? Any help is appreciated, thanks, Greg
Old Mar 24, 2011 | 10:34 AM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
Re: Air vents not working
Mine go out from time to time... it's really weird.
I'd try looking under the hood and make sure all your vacuum hoses are hooked up.
Old Mar 24, 2011 | 11:01 AM
See if this fits your symptoms.
Old Mar 24, 2011 | 11:59 AM
JakeRobb's Avatar
Super Moderator
Can you hear the blower motor if you turn the fan up all the way? If so, my guess is that shoebox is right. If not, check fuses/wiring and then the motor itself.
Old Mar 24, 2011 | 01:42 PM
Greg88's Avatar
No I dont think u can hear anything at all, i'll check again, if it is the motor, where is that located?
Old Mar 24, 2011 | 02:05 PM
Under the RH side of the dash. A better explanation of what your symptoms are would net you better help.
Old Mar 24, 2011 | 04:02 PM
Greg88's Avatar
ok, well i'll check it out later, do i need to remove the dash to get to the motor?
Old Mar 24, 2011 | 06:49 PM
Not really "LT1 Based Engine Tech". Let's move it where it belongs.
Old Mar 30, 2011 | 05:24 PM
Greg88's Avatar
OK so i checked it out. There is abosolutely nothing there! The rear defrost button doesnt even light up anymore. No noise or nothing I checked some fuses, but wasnt 100% sure which one it was. any help?
Old Mar 30, 2011 | 06:16 PM
moparman's Avatar
What do you mean? There's no motor?
Old Mar 31, 2011 | 07:44 AM
Greg88's Avatar
no, theres a motor, but when i turn on the fans on all the settings, there is no air or even noise coming from anywhere? and the rear defrost light doesnt even turn on anymore. Must be something electrical?
Old Mar 31, 2011 | 09:29 PM
Greg88's Avatar
any ideas guys? any help is appreciated!!
Old Apr 1, 2011 | 07:21 AM
JakeRobb's Avatar
Super Moderator
It's really hard to diagnose electrical problems remotely. If you've checked all of the fuses, and you're not up to tracking it down yourself with a multimeter, it's time to take it to a pro.
Old Apr 1, 2011 | 09:01 AM
Greg88's Avatar
ok, well thanks for the help guys.
Old Apr 6, 2011 | 02:26 PM
Greg88's Avatar
well i found the issue, it was HVAC fuse blew, so i put a new one in, and bam, 10 seconds later it blew again. Now its time to start tracing wires, anyone know where I should start? I already took off the switches and i did not notice any loose or unnormal wires. Is this a regular thing that happens? Thanks for the help.
