air only coming out floor setting
i have a 96 camaro and the air will only blow from the floor vents, i tried switching back and forth between face,defrost, and theres no switch, just floor, can anyone help
Re: air only coming out floor setting
Usually, it means there is a problem with the vacuum system that operates all the flapper doors that control where the air goes. The usual culprit is the vacuum check valve, which breaks pieces off.
Shoebox has all the required info:
http://shbox.com/1/vac_check_valve.jpg
http://shbox.com/1/hvac_vacuum.jpg
95chwagon
Jan 13, 2015 09:19 PM
