Air conditioning lt1/ls1
Old May 17, 2020 | 09:20 AM
Dub Wair's Avatar
ls1/lt1 a/c conversion need help
(Conversions & Hybrids)
94 camaro eng swapped and stand alone Psi harness without Ac pressure switch, low mounted LS ac Compressor-.custome hoses already made to fit. I'm not sure about vacuum lines, are there some needed for Ac also not sure where my pressure switch is. Sold lt1... Also clearance issues with Ac compressor tensioner and sway bar.
05-04-2020 03:59 PM by Dub Wair
Old May 18, 2020 | 08:50 AM
DrewHMS97SS's Avatar
Re: Air conditioning lt1/ls1
I don't have an answer to your question, but am curious why the swap?
Old May 18, 2020 | 09:01 AM
Dub Wair's Avatar
swapped the engine from Lt1 to Ls1 ,engine was shot
Old May 18, 2020 | 09:12 AM
OK.... when I read the first post it sounded like you were just swapping the AC components....
Old May 18, 2020 | 04:38 PM
That's what I thought too, and I was curious of what the benefit would be.
If you did a full LS swap, didn't the PCM come with the cabling to connect the pressure sensor? As far as I know, the A/C will not turn on when the sensor is either not present or detects low pressure. If your custom lines don't have this connection, you will either need to add it, or figure out a way to trick the sensor into thinking the pressure is good (while understanding you run the risk or running the A/C with low or no pressure, destroying your components).
JACLT1S
Apr 11, 2013 03:05 PM
gitsum
Jul 28, 2006 03:44 AM
Todd UNF
May 12, 2005 08:23 AM
Pig Pen
May 10, 2005 07:06 PM
Senator
Mar 28, 2004 10:27 PM
