AC service questions
Old Aug 28, 2011 | 04:10 PM
charliediss's Avatar
I have had nothing but trouble with my AC for the past few years, I have now decided to overhaul it. This is my plan of action, am I missing anything?
Compressor is operating sluggishly and intermittently locking up, causing belt squeal so I have decided to replace the compressor with a new GM/Delphi unit. While engaged, I am going to replace the expansion valve and receiver/dryer. I ordered both new OEM replacements for both from the dealer.
Is there a measurable advantage to a new condenser? It is not leaking, nor has given me any reason so suspect fault. However, if in principal only, the condenser functions similarly to a radiator which often benefits when a flush descale cleanses it out.
Any feedback would be GREATLY appreciated.
Charlie
Old Aug 29, 2011 | 02:37 AM
L.dookie's Avatar
Re: AC service questions
it should be cleaned out well if you don't replace it. if any part of the compressor has worn down and come loose, or if the compressor takes a complete dump, the condensor will get clogged full of crap. that being said, some of the crap will go through it then plug up about everything else. you'll want every component as clean as possible to prevent further problems including your hoses and pipes.
Old Aug 29, 2011 | 05:45 PM
Nickw059's Avatar
I wouldn't replace your expansion valve. But whenever replacing your compressor always replace the receiver dryer. Just make sure your a/c condenser isn't plugged up.
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
Injuneer
Dec 15, 2014 09:36 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
