AC Question
Old Aug 17, 2005 | 02:47 PM
JohnD's Avatar
AC Question
I went to hook up my vintage 90's AC gages on the Z and it looks like it is now some sort of fitting like an air coupler. Where can I get hoses or adaptors to fit my gages to the car? I did a cursory look at autozone and didn't turn anything up.
Old Aug 17, 2005 | 08:50 PM
Dave89IROC's Avatar
Re: AC Question
your old gauges are for R12, all cars since 94ish(some earlier) use R134-A, which uses different fittings
Old Aug 18, 2005 | 06:56 AM
cehan's Avatar
Re: AC Question
Yeah, you'll have to get a gage set for 134A. You don't want to use the same equipment from the R12 on the 134A. The R12 used a mineral based oil and the 134A uses a synthetic oil and the two are not compatible (actually the seals and o-rings will deteriorate). You don't want to contaminate either system with the wrong lubricant, which might have some residual amounts left in the gage set hoses. Of course the refrigerants are different too. That's why the fittings are different.
Old Aug 18, 2005 | 09:14 AM
Kataklysm's Avatar
Re: AC Question
1992 was the year that basically everyone had R134A You should just get a new set of gaugues, they aren't that expensive. There is a retrofit kit though that you can buy.
Old Aug 18, 2005 | 10:14 AM
Dave89IROC's Avatar
Re: AC Question
not really, I know for a fact that a 92 camaro was R12, and a 93 grand prix was R12, so, no, everything was not R134-A in 92, 94 was the year, everything after 94 will be R134-A
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
