AC grinds when disengaged
Anyone else have this problem? It comes and goes - but only when the AC is off. Its a metal on metal sound - like the clutch doesn't fully disengage. As soon as I turn on the AC - it goes away.
I fix 3-5 of these similiar noises a week in the summer. The a/c clutch drive plate breaks one of the fingers or gets weak and rubs on the hub causing a noise. If you got a good parts guy they can normally find just the drive plate. I use only ac delco parts for these becuase no one else is willing to look hard enough and sau just put a compressor on it. It does take a special tool to change them but you can ebay the tool for minimal expense. 90% of them only need the plate and not he hub. Look at the drive plate and see if it is touching or if there is a gap about a lottery ticket thickness
If all you are doing is servicing the clutch and/or hub, you do NOT need to discharge the system. The only special tools you will need are a set of snap ring pliers and feeler gauges.
Formula Steve
Sep 19, 2023 08:31 AM
