AC grinds when disengaged
Old Apr 12, 2010 | 03:30 PM
scottso's Avatar
Anyone else have this problem? It comes and goes - but only when the AC is off. Its a metal on metal sound - like the clutch doesn't fully disengage. As soon as I turn on the AC - it goes away.
Old Apr 12, 2010 | 05:12 PM
rngilliland's Avatar
It's the compressor clutch bearing. When the clutch is engaged the bearing stops spinning and the noise stops.
Old Apr 13, 2010 | 04:39 PM
scottso's Avatar
Replaceable? Or am I looking at a new compressor?
Old Apr 13, 2010 | 05:38 PM
On my 94 the dealer replaced the bearing. I don't know if a 2000 is any different. I would check with a shop that does A/C work or the dealer.
Old Apr 13, 2010 | 09:43 PM
byrons1502's Avatar
I fix 3-5 of these similiar noises a week in the summer. The a/c clutch drive plate breaks one of the fingers or gets weak and rubs on the hub causing a noise. If you got a good parts guy they can normally find just the drive plate. I use only ac delco parts for these becuase no one else is willing to look hard enough and sau just put a compressor on it. It does take a special tool to change them but you can ebay the tool for minimal expense. 90% of them only need the plate and not he hub. Look at the drive plate and see if it is touching or if there is a gap about a lottery ticket thickness
Old Apr 15, 2010 | 12:25 PM
scottso's Avatar
Wow - good info. Does it involve discharging the system / removing the compressor, or can it be done on the car?
Old May 24, 2010 | 06:57 PM
Z28kev's Avatar
just hhad the same problem i replaced my ac compressor and its all better the bearings in the clutch are gone if u look closely you might see ac puilly walking back and fourth
Old May 25, 2010 | 10:34 AM
Marc 85Z28's Avatar
If all you are doing is servicing the clutch and/or hub, you do NOT need to discharge the system. The only special tools you will need are a set of snap ring pliers and feeler gauges.
Formula Steve
Sep 19, 2023 08:31 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
Greg88
Aug 24, 2015 07:59 AM
