ac compressor!!
Old Jun 3, 2004 | 05:48 PM
crAzy95z28's Avatar
ac compressor!!
well went to go refill it, didnt work!!
so the compressor is out huh? has about 100k miles on it.....
if so how hard is it to change?
randy
Old Jun 3, 2004 | 05:55 PM
crAzy95z28's Avatar
it blows warm/hot air....so did the compressor go out or what? or did a fuse blow and the compressor not click on?
Old Jun 3, 2004 | 06:08 PM
crAzy95z28's Avatar
ok when i turn it on max a/c it doesnt click on ( the compressor) so how do i check to see if the relay is bad? or what could be wrong? i changed out 2 relays under the engine the FOG light one and the A/C one and nothing...
please help
randy
Old Jun 3, 2004 | 06:35 PM
crAzy95z28's Avatar
ttttttttttttttttttttttttttttttttttttttttttttttt
Old Jun 3, 2004 | 07:39 PM
Dave Feerst's Avatar
I got a compressor that works, if you find out thats your problem PM me if interested.
Old Jun 3, 2004 | 08:35 PM
Josh'95Z28conv's Avatar
With the engine off, reach down there and see if you can turn the compressor clutch. My compressor just locked up. If yours did the same, you wont be able to trun it.
I was also told that most of the time its the low pressure switch. Im not sure where its at because I couldnt find it I took it to a shop that had a free ac inspection and they pointed out to me that the compressor was locked up. Just somethig to check out anyway
Old Jun 3, 2004 | 10:02 PM
dnz28's Avatar
a pull the relay and make a jumper, watch to see if the clutch ingages if it does then its just low, on the other hand if it was like mine it spewed belt smoke, either way ac delete is the way to go, its a mucsle car not a ***** wagon, who need ac.
Old Jun 3, 2004 | 11:21 PM
BigBlue95Z's Avatar
You really need to get a manifold gauge set on there b4 you can assume anything. Go to a local shop and get it looked at. A/C systems aren't a DIY type of system strictly b/c no(normal) person has a gauge set, recovery, or recharge equip in the garage......
Old Jun 6, 2004 | 09:31 AM
Eff's Avatar
Eff
I'm "normal" I think
And I have a gauge set!
And I've never worked in any shop besides a tire shop.
I'm EPA 609 and ASE certified too so I can even leagally use my gauge set
Old Jun 6, 2004 | 03:20 PM
crAzy95z28's Avatar
well cool...my rear end just about blew up, along with no ac....2 things i hvae to fix now...wel actually i chipped about 10 teeth on my rear so now i have to get a new set of gm gears...since i had 3.73 gears installed alreadty, would I have to buy another installation kit ( only been about 5-6 months with the 3.73 in ) or can i just buy the gears and install the ring and pinon?
and how does 175 for a pro install sound on a gear install?
randy
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
