98-02 z28 have posi?
Old Mar 3, 2012 | 05:19 PM
Javi_1591's Avatar
dumb question i have 2001 z28 and my friend said it doesnt have posi but i thought all v8 came with posi?
Old Mar 3, 2012 | 06:59 PM
Canadian Z's Avatar
Re: 98-02 z28 have posi?
It should ....torsen i do believe just open drivers door look at the build sticker. If you see the code G80 then you have posi/limited slip.
Old Mar 3, 2012 | 08:30 PM
cars3's Avatar
Well I don't know about the 98-02 cars but I know the 82-92 V8 cars did not all come with posi. Of my 4 I own now, only 3 have posi. My 89 formula with the 305 only has limited slip.
Old Mar 3, 2012 | 10:58 PM
All 4th Gen V8's left the factory with a limited slip differential. GM calls a limited slip differential "positraction". They are the same thing.
Old Mar 4, 2012 | 12:52 PM
cars3's Avatar
Then why do my cars have 2 different codes. 1 for limited slip and 1 for posi.
Old Mar 4, 2012 | 01:54 PM
97z28k&N's Avatar
He said "all 4th gen V8s". 3 of your cars are 3rd generation.
Old Mar 4, 2012 | 05:54 PM
Post the codes, and we'll look them up.
And it has nothing to do with whether its a 3rd Gen or a 4th Gen. I'll go back to the first GM car I bought brand new with a limited slip differential. It was a 63 Impala 300HP/327ci, 3-speed manual trans. It had only three options on it - a 3.36 limited slip "Positraction" differential, an AM radio, and HD suspension. Then there was a 66 GTO, 389 Tri-Power with a 4-speed. I order it from the factory with a limited slip differential but at that point only Chevrolet used the trademark "Positraction", Pontiac called it "Safe-T-Track". We could go on, but you should get the point.
"Positraction" was a GM trademark for a limited slip differntial. It was shortened by the gear heads to "posi". Traditionally, is was a clutch-type limited slip, but as you can see from a comment above, in the 4th Gens a Torsen gear-type limited slip differential was used.
Post your codes.
Old Mar 4, 2012 | 09:58 PM
cars3's Avatar
Post your codes.
1989 formula 305
GU2 = axle rear, 2.73 ratio
G86 = axle, limited slip
1989 formula 350
GW6 = axle rear, 3.27 ratio
G80 = axle positraction, limited slip
G92 = axle rear ratio, performance
1992 z-28
GU5 = axle rear, 3.23 ratio
2001 ss
Old Mar 5, 2012 | 08:36 AM
Javi_1591's Avatar
Your right has the code g80 thanks great to know
Old Mar 5, 2012 | 05:01 PM
But it clearly indicates, per what you just posted, that G80 positraction is a limited slip. One code G86 for a limited slip that for some reason is not called positraction, and another code G80 for a limited slip this is called positraction. They are both limited slip.
Old Mar 5, 2012 | 11:08 PM
cars3's Avatar
I'm not saying a posi is not limitied slip. What I am saying is that you can have limited slip with no posi. Only one wheel on my formula 305 will drive at one time not both, with the passenger side being the primary drive wheel.
Old Mar 5, 2012 | 11:17 PM
Then your limited slip differential is worn out.
By definition, positraction is the GM trademark for a limited slip differential. Has been for 50 years.
Go to the bottom of this Wikipedia article:
Limited slip differential - Wikipedia, the free encyclopedia
Factory names
In the 1950s and 1960s many manufacturers began to apply brand names to their LSD units. Packard pioneered the LSD under the brand name "Twin Traction" in 1956, becoming one of the first manufacturers. Other factory names for LSDs include:
Alfa Romeo: Q2
American Motors: Twin-Grip
Buick: Positive Traction
Chevrolet/GMC trucks (after 1973): Gov-Lock and Positraction
Chrysler: Sure Grip
Dana Corporation:Trak-Lok or Powr-Lok
Ferrari: E-Diff
Fiat: Viscodrive
Ford: Equa-Lock and Traction-Lok
International: Trak-Lok or Powr-Lok
Jeep: Trac-Lok (clutch-type mechanical), Tru-Lok (gear-type mechanical), and Vari-Lok (gerotor pump)
Oldsmobile: Anti-Spin
Pontiac: Safe-T-Track
Porsche: PSD (electro-hydraulic mechanical)
Saab: Saab XWD eLSD
Studebaker-Packard Corporation: Twin Traction
TVR: Hydratrak
Or, from howstuffworks:
http://www.howstuffworks.com/differential.htm
In this article, you'll learn why your car needs a differential, how it works and what its shortcomings are. We'll also look at several types of positraction, also known as limited slip differentials.
Old Mar 6, 2012 | 12:12 AM
cars3's Avatar
Well then that could clear up a thread I started about 2 years ago. I'm not fixing it because it's only my work car and let's just say there is not much left to the body, but the drive train is in perfect condition. Not much longer and I'll have a fred flintstone car.
Old Mar 6, 2012 | 08:25 AM
rv93's Avatar
your axle is shot. even on one without limited slip, both wheels get equal torque. there is no "primary drive wheel"
LT14LIFE
Feb 9, 2015 09:35 PM
rwferguson43026
Feb 6, 2015 10:06 AM
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
