97 Z28 Fuel Pump Problem
Old Dec 13, 2012 | 11:15 AM
weedog's Avatar
97 Z28 Has A Pressure Reading Of 40 I Just Put A New Electric Fuel Pump On The Car About 2 Years Ago Could There Be Another Problem Making It Give A reading Of 40 It Started From Cranking Right Off To Taking 40 To 50 Seconds To Start A When It Did It Flooded Real Bad For About A Minute Then Ran Ok But Cut It Off And Start It Back Up 5 Minutes Later Same Thing 50Secs To Crank And Miss And Flood To It Clears Up About 1 Minute THANKS
Old Dec 14, 2012 | 04:13 PM
Re: 97 Z28 Fuel Pump Problem
For starters, turn off the "caps lock". The software will not allow you to post in all caps, so it only capitalizes the first letter of each word, making you posts look strange, and hard to read, particularly when you aren't using any punctuation..
Under what conditions does your fuel pressure read 40psi? What is the pressure when you allow the pump to prime, without starting the engine? When the pump shuts off after priming, how fast does the pressure drop?
The engine should start fine with 40psi, and should not flood.
At idle, what is the pressure with the vacuum compensation line off the fuel pressure regulator? How much does the pressure drop when you reattach the vacuum line? While you have the vacuum line off, check it for wet fuel.
It sounds like it's flooding. Have you tried starting the engine with the accel pedal on the floor BEFORE you turn the key to "start", holding the pedal on the floor until it starts? That puts the computer in "clear flood" mode.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
