96 Roadmaster LT1 put in 95 Camaro
Old May 14, 2009 | 10:52 PM
RC_CADMAN's Avatar
Well i finally switch out my blown LT1 for another LT1 from a Buick Roadmaster. I tried hooking the trans up to engine and the rear of the crank wont allow the spindle from the trans to enter the it. I noticed that the rear of the crank on the Buick is different from the one from the Camaro. The only thing i can think of id that the Buick was an automatic and the Camaro has a T-56. Now, my question is, Is that piece at the end of the crank just press fitted or is it form with the crank?
Old May 15, 2009 | 07:00 AM
There should be nothing in the end of the crank with an automatic, but a manual trans car will have a pilot bearing or bushing that can be removed.
Old May 15, 2009 | 12:45 PM
RC_CADMAN's Avatar
How do i remove the pilot bearing? Do i just pry it off?
Old May 15, 2009 | 07:50 PM
Spartan7's Avatar
If I read it right, then the LT1 from the auto Buick is going in the manual Camaro. Then all you need to do is install a pilot bushing in the crank of the Buick LT1.
Old May 16, 2009 | 03:07 PM
RC_CADMAN's Avatar
Do i need a special tool to remove the pilot bearing?
Old May 16, 2009 | 03:27 PM
Spartan7's Avatar
Why? Just leave the old one in the Camaro engine and put a brand new one in the Buick engine.
Old May 16, 2009 | 06:11 PM
briand069's Avatar
Can you post a picture of the rear of the crank from the Buick?
Old May 18, 2009 | 09:44 PM
RC_CADMAN's Avatar
After doing a little more research, I think all i have to do is press the new bearing into the end of the crankshaft. Hope this is all i have to do. I thought i was going to have replace the whole end peice of the crank.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
