95 Z28 trouble code 23
Old Aug 22, 2019 | 04:54 PM
Sidewyz28's Avatar
Car has problems starting once car warms up coolant fans come on and check engine light comes on at the same time
Getting trouble code 23 in my 95 z28
Manifold air temp sensor signal too low (MAT)
what could this be? Where to start?
Like always any help is appreciated
Old Aug 22, 2019 | 06:05 PM
Re: 95 Z28 trouble code 23
The description is much clearer on Shoebox's list, because it is specifically for the LT1.
http://shbox.com/1/Dtcs.htm
IAT (intake air temp) sensor is the one plugged into the side if the rubber intake elbow. High voltage, low temp indicated.
http://shbox.com/1/iat.jpg
Sounds like the harness connector may have fallen off. If it’s not that, use Shoebox’s test procedure:
4th Gen LT1 F-body Tech Articles
Old Aug 23, 2019 | 12:10 AM
Sidewyz28's Avatar
Thanks again injuneer I ended up having an extra intake elbow cleaned up the contact points real good on the sensor and the elbow plugged it back in & now it starts up good as new👍🏼
plattted
9
Sep 20, 2015 11:23 AM
mikesz
Oct 19, 2005 01:02 PM
5H9D0W
Jun 29, 2005 09:00 AM
nonojoe66
Nov 29, 2004 11:28 PM
warwickbass
Aug 21, 2004 09:57 PM
