95 z28 slip and slide
Old Jan 17, 2024 | 03:04 PM
Ayjomi's Avatar
I slide and crashed my 1995 z28 Camaro is this fixable?
If so how hard, how much, etc…
Old Jan 18, 2024 | 03:26 PM
RUDEDOG's Avatar
Re: 95 z28 slip and slide
Yes. If it were me I would try and find a donor car and swap parts.
Old Jan 19, 2024 | 09:21 AM
Ayjomi's Avatar
Ok cool, how do I go about pulling the frame back out? It’s currently digging in to my front passenger wheel. I found a 2001 black Camaro rolling body. How much work to drop front k member and back axle to swap body’s?
Old Jan 19, 2024 | 09:32 AM
RUDEDOG's Avatar
A Winch Puller might work.
Old Jan 19, 2024 | 10:26 AM
RUDEDOG's Avatar
Check out the Engine Removal Guide Sticky in the LT1 Forum. K-Member, Engine, Transmission Removal.
Old Jan 19, 2024 | 11:34 AM
If you're going to transplant your 95 engine into a 2001 chassis, there will be mismatches trying to connect the 95 engine harness to the 01 chassis harness. Wiring will be significantly different, since the 01 uses a body control module to replace a variety of small modules in the 95.
Old Jan 21, 2024 | 07:54 AM
Ayjomi's Avatar
Is it possible to rip chassis harness out of 2001 and swap it with the 1995? I’ll switch the top end of dash if needed
Old Jan 21, 2024 | 08:58 AM
Anything is possible, but probably a huge amount of work.
Old Apr 1, 2024 | 08:25 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs down Re: 95 z28 slip and slide
If you have damage to the frame, even if fixed correctly, the vehicle will never be the same. If you have insurance, I guarantee they will "total the vehicle" and all you can do at that point is purchase it back with a salvaged title. That type of repair will cost more than the vehicles worth.
I would cut my loses, and purchase another vehicle that is in you price range. JMHO
skirocz28
Apr 4, 2014 11:46 AM
Tmd3500
Cars Wanted
9
Apr 7, 2008 07:33 PM
RedRocketZ28
Jul 6, 2007 01:04 PM
LALT1
May 6, 2007 12:13 AM
detroit1994z28
Aug 25, 2006 08:10 PM
