95 Z28 Ignition cylinder problem need help!
Old Dec 24, 2012 | 09:40 PM
Kavedra's Avatar
Guys I think my ignition cylinder is completely shot, something must have fell apart on the inside of the cylinder because I can't even insert my key. Thank goodness this happened at home. I looked into replacing the cylinder but I believe the ignition has to be turned back into the lock position for it to be removed. I can't get my key in so is that possible without tearing some **** up? I can wire up a push button start but I have an a4 trans and I don't think it will shift out of park with the ignition like it is. What do I do??! I guess if all else fails I can just go in there and break what I need to but.. I'd appreciate any input anyone has to offer
Old Dec 25, 2012 | 04:11 PM
Dave89IROC's Avatar
The cylinder can be removed without rotating it, but the airbag, steering wheel, clockspring, lock plate and turn signal switch need to be removed
Old Dec 25, 2012 | 08:29 PM
Kavedra's Avatar
Re: 95 Z28 Ignition cylinder problem need help!
Thanks, I got it sorted out.
DirtyDaveW
Dec 1, 2016 05:37 PM
tds1213
Nov 27, 2014 12:55 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
