95 Trans Am Where is the blower motor resistor
Put the dash back in and now the blower motor doesnt work. I have a wiring schematic of the hvac sysytem and I cant test it because I cant find it. I know where the blower motor is and I have the glove box out but still cant find the resistor.
Re: 95 Trans Am Where is the blower motor resistor
Could you be a little more specific as far as how far to the left of the blower motor.I have the glove box out and the bottom interior cover off and there is no blower motor resistor that I can see. According to my wiring diagram there should be 4 wires going into it and I can even see 4 wires anywhere close to where Im looking. I really dont want to tak e the dash back out.
the blower motor relay is located behind the stereo. pull the stereo and the under dash kick panel. you will see it to the left rear of the steroe attached to post and it slides up off of the post. The resistor pack plug is located at the front right of the center shift console. you have to take out all of the bolts holding the console down and move it backwards. the shifter plate snaps off and you have to put the sfiter into drive to get clearance. the plug is also attached to a post and it has a clip and slides off the post. the wire follows underneath the plastic box behind the dash and on the floor. follow the wire to the resistor location which is under the glove box against the firewall in the left corner behind the round temperature control. you have to reach all the way back in the corner to feel it because you cannot see it. it has 4 wires and one screw that holds it to the outside of the bottom of the heater box.
Jan 5, 2015 07:14 PM
1LEThumper
Jul 14, 2003 12:45 PM
