89 Iroc Z28 fuel in crankcase
Old Jan 8, 2023 | 06:23 PM
Eagles318's Avatar
So I bought this 89 Iroc Z28 Convertible 5.0 tpi, ran when I bought it, got it home and was looking over everything (bought it as a project car) pulled the dipstick and there's fuel mixed with the oil. Am I right in thinking a possible injector leak or maybe the fuel pressure regulator? Previous owner said they replaced the injectors and rebuilt the regulator. Thanks for any help!
Old Jan 10, 2023 | 09:58 AM
TopKiwi's Avatar
Re: 89 Iroc Z28 fuel in crankcase
first thing id do is check your compression and do a leakdown test to establish the health of the cylinders. drain the oil out into a clear bucket as well and let the oil and fuel seperate to judge just how much fuel is leaking into the oil. its possible that the piston rings are allowing fuel to get past them, you'd also see other signs like excessive crankcase blowby. but definitely start with the basic compression/leakdown tests and report back with your findings.
if those tests come back okay, next thing id check is for the injectors to be stuck open dumping fuel.
also are we talking about stock fuel system? fuel pump, fp voltage, injectors, line pressure etc? more information always helps
Purewal590
3rd Gen / L98 Engine Tech
Feb 15, 2017 10:36 PM
gonzo275rltw
Jul 10, 2015 11:47 AM
ramhead97
Jul 8, 2007 08:56 AM
pyro45
Parts Wanted
Apr 22, 2004 12:53 PM
chevyman502bb
46
Aug 12, 2003 09:19 PM
