Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
89 Iroc Not starting
Old Jun 27, 2007 | 10:54 PM
ramhead97's Avatar
I have an 89 iroc, Ive replaced the fuel pump,filter, plugs, wires, cap,rotor,coil and the car still will not start. Im not sure if my ecm is bad, or if i need a crank sensor. I have tried unplugging the mass air flow sensor so that it would run on its base timing and fuel, but that did not seem to work. Any suggestions are greatly appreciated. The car starts on starting fluid and then dies out. Also right before it died for good, it was bogging like something fierce. Thanks
Old Jul 8, 2007 | 08:56 AM
Guest47904's Avatar
Guest
By using starter fluid you proved the ignition system is working. Look at fuel pressure and then at injector pulses.
dale3in98
Feb 14, 2015 12:18 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Amshnock
14
Jan 18, 2015 11:47 AM
capebuf
Jan 13, 2015 07:22 PM
