69' Maro Taillights
69' Maro Taillights
Taillights fail to work most of the time, this pertains to just the driver's side taillights. First off, the braklight will work less than half the time and the brake light hardly ever works. Sitting in the garage I can wiggle the light bulb connectors to make them all work. Then whenever I get on the road, they all seem to quit working. All connections look good from taillights all the way back to the rear partition. I would like to drive it sometime without getting tickets! Help please? J.Vanderslice
Re: 69' Maro Taillights
if you can wiggle the bulbs, sounds like you need new sockets
just FYI, here is how the circuit is layed out
battery, to horn relay, to fuse box, to brake light switch, to turn signal switch, to rear lamps
Magenta_Hearts
Mar 25, 2015 10:24 AM
