396 stroker is .30 over right??
Old Feb 22, 2006 | 01:55 PM
detroit1994z28's Avatar
Someone is selling a 396 stroker lt1 shortblock in my area and it's .30 over pistons. Is a 396 stroker .030 over. I thought it was a .40 over block?
Old Feb 22, 2006 | 01:57 PM
IllusionalTA's Avatar
Re: 396 stroker is .30 over right??
3.875 stroke w/ a 4.030 bore and a 5.85 or a 6" rod will give you a 396 so yea.. just find out who did the machine work, etc.. I had bought a 396 short years back only to find out water jacket's have been broken through and bunch of other issue's w/ improper machining and clearancing..
Old Feb 22, 2006 | 03:57 PM
OldSStroker's Avatar
DISPLACEMENT = BORE X BORE X STROKE X#CYL X .7854
BTW, rod length doesn't enter into displacement calculation.
"30 over" is .030 over not .30 the stock 4.000 bore.
If you do the math, .030 over = 395.4 cubes and .040 over = 397.4 cubes.
No big deal on cubic inches, but .040 over bore is pushing it on some LT1 blocks if you are making much power.
"Used stroker shortblocks are a lot like used brides: you are never sure what you are getting into." ----B.T.D.T.
Old Feb 22, 2006 | 03:58 PM
Pure Genius... btw just providing common rod's for the combo...
Old Feb 27, 2006 | 12:34 AM
JohnnyPappis's Avatar
can ayone point me in the direction of some strong 5.850 rods? i heard 6 would put to much stress on an F/I motor?
Old Feb 27, 2006 | 05:49 AM
Lunati, Callies, oliver,eagle all make 5.85 rod's.. Just more based on your budget..
Old Feb 27, 2006 | 08:04 AM
im looking for somthing to hold to the rigors of 700 rwhp
Old Feb 27, 2006 | 09:19 AM
The problem isn't the 6" rod putting too much stress on the motor. Its the fact that the wrist pin is so high on the piston that it causes problems interfering with the rings, and leaves you with a short compression height. I run the Oliver billet 5.85's with the kind of power level you are looking at. I've seen the Olivers stand up to a blown 383 putting down close to 900rwHP.
Old Feb 27, 2006 | 11:52 AM
Alright only problem is could you point me into a vendor that sells that specific rod i cant seem to find it thanks
Old Feb 27, 2006 | 12:44 PM
You have to check for a vendor that sells Oliver parts..... the shop that built my engine got them direct from Oliver. Be prepared for "sticker shock" when you see the price.
http://www.oliver-rods.com/products/BilletIndex.html
Old Feb 27, 2006 | 01:12 PM
i know im in for a good over a grand about how much did they get yours for?
Old Feb 27, 2006 | 03:20 PM
I bought mine 6 years ago.... I think about $1,100. I need to check and see which bolts I got with them. I don't think I got the one that cost $500 extra.
Old Feb 27, 2006 | 05:15 PM
would you happen to have the part #?
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
