2000 Camaro differential fit in 2001
Old Mar 18, 2012 | 07:16 PM
Javi_1591's Avatar
My 2001 z28 needs a differential someone is selling it from a 2000 Camaro is it the same?
Old Mar 18, 2012 | 07:28 PM
jloshotz's Avatar
Physically it will fit. Only differences should be three or four channel, a four has an abs sensor at each wheel, a three has a single abs sensor on top of the diff housing. If you have traction control, (asr) make sure the donor does as well.
Old Mar 18, 2012 | 07:38 PM
Javi_1591's Avatar
Re: 2000 Camaro differential fit in 2001
Gonna buy the differential for 200$ what do I need to look at to know it's still good . Don't wanna buy a broken differential
Old Mar 18, 2012 | 07:47 PM
jloshotz's Avatar
Spin it slowly by the yolk, while creating light resistance on the axle and feel for smoothness. Of Course this isn't even kind of fool proof, hopefully you can pull the cover for a visual inspect. Be sure the axle you are swapping has the sam gear ratio, or at least know what the gear ratio of the new rear is, and what you have in yours.
Old Mar 23, 2012 | 01:15 PM
Javi_1591's Avatar
i got the differential and gonna put it on myself tommorow hopefully everythings good and my baby will be running like a beast again
Old Mar 23, 2012 | 07:52 PM
By "2000 Camaro" do you mean a V6 model? If so, was the V6 equipped with the optional (in the V6) limited slip differential?
Old Mar 25, 2012 | 11:59 AM
Javi_1591's Avatar
it was also a v8 ... i switched them and everything fit perfectly and car ran great
Old Mar 25, 2012 | 06:41 PM
An "open" differential will fit the same as the limited slip, and it won't change the way the car runs. But it will lead to one-legged burnouts.
If they were both from V8 models, they will both be limted slip.
Alien
West South Central
Jan 11, 2015 12:51 PM
jdohman
Aug 17, 2002 09:55 PM
BigManJ
Aug 12, 2002 02:47 PM
Mad_Ice
Jul 29, 2002 09:44 PM
2000silverz28
Jul 20, 2002 06:14 AM
